SS-V: 1060 Cantilever Plate
Test No. VS07Find bending stress at fixed end for a cantilevered plate subjected to a vertical shear load of 120 lbs.
Definition
The load is uniformly distributed along the free end of the plate.
The end constraint boundary condition is sliding with fix line spot at the middle of the end face.
The units are IPS.
- Properties
- Value
- Modulus of Elasticity
- 10.7e+6 psi
- Poisson's Ratio
- 0.3
Results
Theory | SimSolid | % Difference | |
Maximum Bending Stress (psi) | 6.000E+04 | 6.1150E+03 | -89.81% |
